rico aficio gestener DSm 615 copier, cover open or cover is open problem
  • nashonussp
    • Jul 2025
    [Error Code] rico aficio gestener DSm 615 copier, cover open or cover is open problem
    my rico aficio gestener DSm 615 is dipslying cover open or cover is open problem.
    what could be the problem!
  • 8T2
    • Aug 2015
    • 257
    Re: rico aficio gestener DSm 615 copier, cover open or cover is open problem
    Most likely a faulty door switch or broken door switch actuator...could also be the small tray 2 cover that is actually open, people tend to miss that one after removing a jam
    Sent from my WAS-LX1 using Tapatalk
    • andrewdecruz
      • Jul 2009
      • 74
      Check for a blown fuse in the power supply unit. Remember facing a similar problem with this model about 10 years ago. Am surprised that there are still some of these models in circulation.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        +1
        Regards Mark
        • Polarbear
          • Feb 2012
          • 1070
          You can also check the switches in service mode to see which ones do not change when actuated.
          Press the GREEN button!!
          • Gab
            • Aug 2015
            • 671
            Are fusing and drum units placed properly?
