Ricoh 7100x 5 color , White spot and black print causing a print delay to 4 pg min
  • swaggen
    • Sep 2017
    • 100
    We are printing a white spot for the 5th color and a black barcode.
    Just white spot with text that is variable, no delay . Great print speeds.
    The moment we introduce the barcode that is printing in black we have a huge print delay.
    We recreate the templated to see if its a bad file. No improvement,
    Is that normal operation for these machines to print this slow when doing a spot color and printing CMYK?
    Re: Ricoh 7100x 5 color , White spot and black print causing a print delay to 4 pg mi
    when printing the barcode .. are you using composite black?
    • swaggen
      • Sep 2017
      • 100
      Not using composite black.
        • 37449
        Are you printing through a fiery?
        What driver are you using?
        What port are you using?
        Since the bar code is probably printed as a graphic, is the print quality set to vector of raster?
