Ricoh Mpw 2400 CIS
  • xpert copy
    • Jul 2019
    • 5
    Ricoh Mpw 2400 CIS
    hi I got really problem on CiS. I have problem in one Cis that print 4" black vertical Line. so i did copy in long way potriat . after long time i got cis and change it. then the problem occur. all the 5 cis not working so i check all the cable the PUI board and all. please give some advice cause of lockdown i cannot get any items from aboard .. plz plz help me
  • Polarbear
    • Feb 2012
    • 1070
    Re: Ricoh Mpw 2400 CIS
    Hi
    So don't any of the CISs work at present? There should be an overlap between them so that the whole image is scanned.
    Press the GREEN button!!
    • mikadonovan
      • May 2008
      • 2931
      Did you do this?
      NEVER ASSUME ANYTHING
      • xpert copy
        • Jul 2019
        • 5
        all 5 cis lamp is not lighting. and there is no sp 4972 code in my mpw 2400...
        • mikadonovan
          • May 2008
          • 2931
          It may be in SSP. That excerpt is from the manual.
          • xpert copy
            • Jul 2019
            • 5
            how to get in ssp mode in mpw 2400
              • 37532
              Maybe you shouldn't be attempting to work on any Ricoh equipment if you need to ask that question.
              • xpert copy
                • Jul 2019
                • 5
                yes i am new on this devices
                • mikadonovan
                  • May 2008
                  • 2931
                  Enter sp mode, hold the "#" key and select the system tab.
                  • Brianneoe
                    • May 2015
                    • 322
                    I would start with putting the old CIS back into the machine and test.
