Ricoh 2035 sc-690
  • Vesigoth
    • Mar 2008
    • 133
    Ricoh 2035 sc-690
    was getting sc-329 (laser unit error) changed to a gest.-745 unit & swapped front board to original from the ricoh-2035 cause connectors are different. now it's giving me a sc-690. is it still the laser unit, because of the front board ? please help. thanks
  • Eric1968
    • 2458
    The manual says :
    690 A GAVD block I
    2C bus error
    An error is detected in the GAVD communication I
    2C control register of the GABIC2.
    I2C bus on BICU defective
    Don't know exactly what this means, but I think it has to do something with the connection between the Laser Unit and the BICU-board.
    Make sure you use Ricoh parts for Ricoh machines. Sometimes parts are different while they look the same.
