Ricoh mp aficio 2000 no error code not printing
  • kingsley dani
    • 6
    Hi all,
    I need your help on this printer, it was fine a couple of weeks ago, but just recently has this problem. Does not display error code but does not print or scan but only photocopy. Also, the printer, scanner and copier light indicators are all off. All fuses are in great shape. Machine starts normally but these functions ( printing and scanning) are seemed disabled.
    Thanks,
    Kingsley
    Re: Ricoh mp aficio 2000 no error code not printing
    Originally posted by kingsley dani
    Hi all,
    Thanks,
    Kingsley
    what have you done to try to rectify the problem?
    disconnect the net cable.. reboot machine do you get any light on NIC card?
    reconnect after power down ... power up
    print internal config page post in pdf format if possible.
    you give little info for to help you so.....
    • kingsley dani
      • 6
      Thanks Phil, when I connect NIC cable it blinks, but then this printer is standalone. Am the only user and I don't use it as a network printer. I have tried a lot of troubleshooting options, check the fans, motors. Tried setting to factory default, but Indicators are all off. I also tried contacting a technician but they seem unfamiliar with ricoh printers. Could it be related to circuit boards so I could order for a replacement?
        • 37550
        DO print and scan show in User Tools and/or SP main menu?
          whoops how did you reset to factory settings?
          did you re-input the settings after factory mode?
          are you formally trained on any machine?
          do you have the service manual?
          WHY do you folks ALWAYS go for a board first?
          was the tech a trained RICOH tech?
          follow the K.I.S.S. system... Keep It Simple Stupid .... meaning DO NOT go looking to a board problem it could be as simple as BAD power or firmware.
          Phil B. " The Dentist "
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            +1 WHOOPS
            Regards Mark
            • kingsley dani
              • 6
              Pressing * and # to restart the machine not really factory reset.
              The manual says if the machine is offline, the offline key should be pressed even at that, it does not come up.
                so why did you tell me that you did 'factory reset'?
                you say you started in 2005 .. but profile says 0-2yrs in industry
                you say you preformed factory reset... then not really
                wind turbines don't count as in 'our insudtry'
                if you can't tell the truth I'm DONE!
                • kingsley dani
                  • 6
                  OK,
                  Phil apologies for the mix up, just needed a quick fix for my equipment not minding the questionnaires. Am just new here. Technicians Around seemed unfamiliar with Ricoh multipurpose product. This is a very important equipment for my productivity. I know you could help please. Just trying to get information to get it fixed.
                    OK,
                    HAVE YOU FOLLOWED SUGGESTIONS THAT OTHER TECHS HAVE GIVEN?
                    Frankly I KNOW this problem is above your pay grade.. HIRE A CERTIFIED TECH.. EOS
                    • kingsley dani
                      • 6
                      Like I said, I tried hiring a new one certified technician but they seemed u familiar with the problem or equipment.
                        you will have to get your solution from another tech I AM FUCKING DONE with this thread.
                          • 37550
                          Does this mean that you are connected by a USB cable? If so have you tried another cable or a different USB port on the computer? What driver are you using. If it is PCL5 you may have been done in by a recent Windows update.
                            • 37550
                            OK,
                            If you cannot or will not answer the questions that we ask, then there is no way that any of us can help you. Without the answers to those questions there s no way we can know what the problem is because we are not standing in front of the machine.
                            • kingsley dani
                              • 6
                              Thanks Phil for your effort, really appreciate. I have 4 different USB cables and the pc has 3 ports. You can hear the sound of the connection to the pc but as long as the copier, printer, and scanner indicators are all off, no printing or scanning can take place.
                              Again, many thanks.
