MPC 4503 adding toner issues
  • fshead
    • 2378
    hi
    Are you seeing issues with the toner supply system on these machines?
    I have to go ck out one where they say the machine is out of toner and the cartridge still has toner in it..
    Dont know more than that..Have not really pulled the toner feed on these but did so on a mpc2503 i gutted..
    are they the same?
    thanks
  • FrohnB
    • Jul 2017
    • 1919
    Re: MPC 4503 adding toner issues
    They are the same.
    We've had mangled toner hoppers on ALL models in the Cxx03 series.
    Not too bad to get to and replace.
    Have also had some backed up dev. units that have caused an add toner condition.
    Omertà
    • fshead
      • 2378
      thanks.
      IF THE DRUM/DEV UNIT TURNS FREELY THEN I ASSUME THE TONER HOPPER IN THE REAR NEEDS TO BE PULLED OUT?
      Do you just vacuum it and reform or it is beyond repair?
      the mpc2503 and mpc4503 toner hopper are a bit different part numbers..dont know if they are any different
      • FrohnB
        • Jul 2017
        • 1919
        If it's turning freely and not making a clicking/grinding/moaning noise then I doubt the dev. unit is the issue.
        If it's indeed the toner hopper then there is no "salvaging it", the toner transport coil breaks off of it's mount and requires replacement.
        Hoppers are the same between all models in the Cxx03 series (C2003 - C5503).
        Newest numbers for the hoppers are:
        D0BQ3240 - Black
        D0BQ3270 - Cyan
        D0BQ3280 - Magenta
        D0BQ3310 - Yellow
        Omertà
        • fshead
          • 2378
          thanks
          getting parts not in stock with covid is a PITA.........local dealer has given me crazy timelines..
          I have a mpc2503 i gutted that worked perfect and a good meter.
          I will take the toner hoppers with me.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Regards Mark
            • fshead
              • 2378
              thanks
              do you get any grunting or grinding when the hoppers go?
              I have yet to have any go..
              here i gotta pay the dealers VIG...
