ODD problem when reducing lgl to letter
  • fshead
    • 2376
    hi
    I was messing with a mpc401sr FW all updated and when trying to reduce legal to letter via ADF it cuts off at the trail edge..1.5 to 2 inches even if i go to 25%
    in reduction..Am i missing something????????????lead edge and reg is all good
  • FrohnB
    • Jul 2017
    • 1919
    Re: ODD problem when reducing lgl to letter
    Can't remember on this model, but it might be that you have to set the ADF to recognize the legal size paper.
    Don't think they have sensors that determine length of paper.
    Omertà
    • fshead
      • 2376
      maybe i have to tell machine mixxed originals.
      but i hit legal to letter on reduction mode
      • fshead
        • 2376
        so i had time to muck thru the machine..
        to make legal to letter reduction you have to hit original type
        and tell it legal and then choose letter tray and hit the reduction 78% and it works..
        always assumed that machine did auto paper detect thru adf..
          • 37561
          On some of those A4 entry level models they can use one of the ADF path sensor s covered time to determine the original length but only when doing mixed originals.
          • fshead
            • 2376
            it wouldnt work in mixed but once i set original to legal from that section it worked..
            • KenB
              Geek Extraordinaire
              • Dec 2007
              • 3944
                • 37561
                When set to mixed size originals, the feed bed length sensor are not used as they will only see the longest original. The length of each originals is determined by how how many clock ticks the original covers one of the path sensors.
