TLS/SSL Protocol on Ricoh MP2504
  • Batman1976
    • Jun 2016
    • 88
    Hi all,
    We had an issue with scan to email via a Gmail account which turned out to be a authentication issue with the password. In the customers infinite wisdom they went on the W.I.M of the device and disabled all SSL and TLS protocols. Now still unable to scan and can't log onto web browser to enable ssl/tls setting.
    Have tried resetting all user setting and network setting via SP 5-801 but no luck. Reluctant to do a memory all clear to avoid having to input all SP data.
    Any ideas on enabling SSL/TLS via device op panel? Or resettting the setting without doing full memory clear?
    Batman1976
    • 37345
    Re: TLS/SSL Protocol on Ricoh MP2504
    You might try entering WIM as a HTTPS:// device.
    • FrohnB
      • Jul 2017
      • 1919
      User Tools --> Machine Features --> System settings --> Interface Settings --> "Permit SSL/TLS" - normally set to "Ciphertext/ Cleartext".
      Omertร
      • mikadonovan
        • May 2008
        • 2931
        Yes. And ciphertext will only work with a device certificate.
        NEVER ASSUME ANYTHING
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Turn on SSL it's under where you add smtp address on machine
          Regards Mark
