RICOH A0 Aficio w240 sc992
  • mgipa
    • May 2020
    • 49
    Hi everybody!
    I'm using a Ricoh w240. It shows error 992, hope everyone help me !!! thanks
  • ThePomqueteer
    • Sep 2016
    • 73
    Re: RICOH A0 Aficio w240 sc992
    - Turn the main power switch off/on. • Go into the SP mode. Do SP7901 to display details about SC992 (software file name, line number, and variable)
    EDIT: Just realized I misread the model number, this is for the W2400, but I just checked service manual for the 240W and it lists pretty much the same solution:
    Set the main power switch to off then to on.• Go into the SP mode.• Input 0 for SP7405 to displaythe data for SC992, whichincludes the software file name,line number, and variable.
    • mgipa
      • May 2020
      • 49
      Originally posted by ThePomqueteer
      Thanks you! It still reports erros. Is thre any other way to deal with it?
      • ThePomqueteer
        • Sep 2016
        • 73
        What does it show when you do SP7405? That should tell you what software is giving you the issue and would be a good place to start.
        • Brianneoe
          • May 2015
          • 322
          Disconnect the cable for the Plot Base unit and reboot. If the problem goes away you may have a bad cable that connects to the plotter. If the problem is still there after you disconnect the cable then try to reload the all firmware modules. If that does not work then replace the IPU board.
