hello
had code 280-02
after replacing bl and col inkthead sc was gone
but when printing color the image shifts (flue) just a little bit. direction paper feed.
I replaced the heads like on the manual but I can't see any adjustment.
It's hard to believe to change both heads or on head and that they are one on one correct without a calibration.
to make it more clear: it's very strange that you can hook up the inkt heads and that the nozzles of the black 100% in place with the nozzles of the color (paperfeed direction)
you can adjust the heads in maintenance mode but that's from left to right (headposition)
regards
had code 280-02
regards
