The privileges..?
  • Tech18
    • Jun 2018
    • 23
    The privileges..?
    Hi All..
    I have MPC 4503
    I try to change the setting for customer .. but it keeps saying ..
    "You don't have the privileges to use this function" ..
    How do I disable this ..?
    • 30307
    Re: The privileges..?
    Originally posted by Tech18
    Hi All..
    What model an make
    • mikadonovan
      • May 2008
      • 2931
      Log in as administrator and add the functions in user tools.
      NEVER ASSUME ANYTHING
      • Tech18
        • Jun 2018
        • 23
        What model an make
        Sorry ..
        It's Ricoh MPC 4503
        • Tech18
          • Jun 2018
          • 23
          I tried that .. won't let me ?
          You mean .. log in Web to change it ..?
          Can you explain more procedures please ..
            • 37533
            What screen were you on? If you are in User Tools, you need to be logged in as admin. If you are not in User Tools, admin does not have any privileges. It is a common mistake many of us have made. We get in a hurry. We go into User Tools and login to make changes. We exit User Tools to test the changes bit forget to log out first.
            • Tech18
              • Jun 2018
              • 23
              There is No Admin Log in UserTool ..?
              It didn't ask me to log in ..
              Do i miss something?
                • 37533
                Unless you are using the Smart Operation Panel the Login/Logout button is located to the right of the number panel right above the User Tools button.
                • Tech18
                  • Jun 2018
                  • 23
                  No, It's a regular control panel ..
                  I think .. customer was playing with it ..??
                    • 37533
                    Then see my first reply. My second tells you where the Login/Logout button is located.
                    • Tech18
                      • Jun 2018
                      • 23
                      I never had to do this before..
                      but i will try when I go back to the customer !!
                      • RustySprocket
                        • Mar 2020
                        • 19
                        Its possible the login button wont be there in User Tools. Youll need to go into the Adminstrator Tools tab and turn on Administrator Authentication in this case.
                          • 37533
                          The Login/Logout button s a physical keyboard switch. It is always there.
                          • RustySprocket
                            • Mar 2020
                            • 19
                            Youre right. Thanks, i forgot that detail. Ive spent too much time with the SOP recently.
                            • KenB
                              Geek Extraordinaire
                              • Dec 2007
                              • 3944
                              I know the feeling all too well...
