Ricoh SP c820dn dirty prints and transfer belt
    Re: Ricoh SP c820dn dirty prints and transfer belt
    READ THE USERS MANUAL
    • kringle
      • Sep 2020
      • 20
      Hi..... It's not in there. just says to select your size in the user menu and hit enter to program. I set the size at it shows and it defaults back to max as though it won't hold the setting. I didn't know if there was a place to change that user default in the system settings. Seems like a machine bug in the user menu.
        • 37491
        With a MFP we could tell you where to go in User Tools to set it to use "Command/Computer Control" instead of "Machine Setting" for paper size and type.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          #19
          Yes, I think you are right. I think the small sheet and minimal coverage is my big issue. Unfortunately, I can't change that.
          Right now I'm running "THICK 1" My belt always looks nasty! It overtones mostly in magenta. but often in other colors too. I feel like if I could just cut the toner supply somehow, I'd be good.
          [ATTACH=CONFIG]46756[/ATTACH]
          The problem is probably the magenta pcdu just check turn the transfer belt see if it cleans of
          Regards Mark
          • kringle
            • Sep 2020
            • 20
            #20
            I have logged in to the printer via the IP. It looks like the paper setting for the bypass tray is
            It is not editable in the web interface. I'd like it to be 7.25 x 5.25
            The toner and ibt setting alterations you sent SEEM to be helping, but I need to figure out how to run out the drums some. you had said I could pull the toners out and run some gray scale sheets, but my machine won't run with the toners pulled out. Can you advise how to do that?
            Thanks for all the assistance.
            UPDATE.... it is editable when I log in with admin credentials.... however, I run 1 envelope and the settings revert to default. So it will not hold the updated paper setting I enter. seems odd.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              #21
              Of course you can't use machine with drums or toners are pulled out just fix the copy quality problem sometimes you will need to fit parts start with magenta pcdu new oem that will setup when installed
              Regards Mark
