Ricoh Mp c6502
  • maurogarcia
    • Sep 2020
    • 6
    [Misc] Ricoh Mp c6502
    hi, i had this issue in my machine, the magenta color always print orange, i feed several times toner to the developer unit and works a little bit, i changed the developer unit with other thats works fine in other machine and prints orange, change the feed motor developer and still orange, i want to saturate the magenta levels but i cant find the option in Sp menu, can anyone help me where can i found it...
  • senakainoki
    • Nov 2019
    • 25
    Re: Ricoh Mp c6502
    Did you done colour calibration...
    • maurogarcia
      • Sep 2020
      • 6
      Re: Ricoh Mp c6502
      yeah, several times but dont work, in fact the print sample copy its ok the magenta prints ok
        • 37550
        Re: Ricoh Mp c6502
        Sounds to me like the yellow PCDU has been throwing toner and contaminated the magenta developer. I suggest replacing the magenta developer and apply all bulletins dealing with toner scattering to all PCDU.
        • mikadonovan
          • May 2008
          • 2931
          Re: Ricoh Mp c6502
          Clean the ID sensors and then run ACC.
          NEVER ASSUME ANYTHING
          • maurogarcia
            • Sep 2020
            • 6
            Re: Ricoh Mp c6502
            how can i run the acc or u refering to a automatic calibration, did you know how in the sp menu can i control the measure of intensity for each color by separated
            thanks for your time
            • maurogarcia
              • Sep 2020
              • 6
              Re: Ricoh Mp c6502
              sorry if i cant understand u, i check the magenta developer integrity and dont had yellow toner over it, i mean orange to tell a reference color but is if the toner dont drop in the right proportion over the paper
              • mikadonovan
                • May 2008
                • 2931
                Re: Ricoh Mp c6502
                It's in user tools under the maintenance tab. If you clean the ID sensors before you perform the adjustment, the machine will AUTOMATICALLY adjust colors to specs. I have taken care of many color issues by simply performing this easy task.
                  Re: Ricoh Mp c6502
                  are you running genuine oem ricoh toner?
                    • 37550
                    Re: Ricoh Mp c6502
                    ACC, Automatic Color Calibration, is in User Tools - Maintenance. Before running it, the ID sensor assembly and all optics must be clean.
                    • maurogarcia
                      • Sep 2020
                      • 6
                      Re: Ricoh Mp c6502
                      yes my dealer its a authorized reseller of the brand in my city
                        • 37550
                        Re: Ricoh Mp c6502
                        That does not answer the actually question. To make it a little more understandable, do the toner cartridges have the Genuine Ricoh label.
                        • mga
                          Copier Technician
                          • Dec 2010
                          • 1393
                          Re: Ricoh Mp c6502
                          Stop swapping parts from other machines if not set up the copy quality will go bad just like the 1st time
                          Regards Mark
                            Re: Ricoh Mp c6502
                            +1
                            • skinnyb
                              • Jul 2008
                              • 291
                              Re: Ricoh Mp c6502
                              +2 Parts are calibrated for one unit and swapping them around screws all that up. Sounds like the machine needs a full vacuum and PM, developer change, the whole nine yards.
                              Sent from my LM-V405 using Tapatalk
