DSC428 admin/supervisor passwords not working
  • fritz.net
    • Sep 2018
    • 9
    Hello, I'm trying to set IP address and other settings of an DSC428. Here the printer interface wants me to login since otherwise these operations are denied.
    So I tried login as admin/admin or admin/blank and also supervisor/blank and administrator/blank and other variations. The supervisor login works (on the machine and also the webinterface). However after saving the new admin passwort the changes seem to not take effect (I did not miss the second apply button).
    I also tried to reset the addressbook which was not working vie SP-Mode.
    I dumped the NV ram the find out the passwords like in ( Lost supervisor password? ) however I don't want to risk damaging anything so I have not tried loading a reseted NV file back into the printer.
    The administrator seems to have an empty password (which is not working). And the format seems to not exactly match (not 4 byte between "marker" and username).
    I also tried decoding the admin password (which was also not working)
    I would appreciate any tips how to gain access back, thanks for your attention.
  • DRichard
    • May 2008
    • 482
    Re: DSC428 admin/supervisor passwords not working
    [ATTACH=CONFIG]46910[/ATTACH]
    Have you ried the Factory Service Mode (the one you use if you need to reenter the machine's ser#)? If you can get there, try using SP5-846-046.
    "Enjoy every sandwich."
    -- Warren Zevon
      • 37590
      My experience has been that the procedure in that thread only works with older B/W models.
      • fritz.net
        • Sep 2018
        • 9
        Thanks for your reply.
        I've read about the factory Service mode, but did not find how to access it (only the hint to search for it - but i only found the "classic" SP Mode). When i go to SP5-846 i miss the numbers between 10 and 47 so there is no 46.
        Thanks for your information. Sounds like bad news
        • DRichard
          • May 2008
          • 482
          How to access this version of service mode has been posted elsewhere on this site (by others who weren't very concerned about making it public). It works fine on all current models of Ricoh MFPs.
          -- Warren Zevon
          • skynetto
            • Sep 2012
            • 257
            Can you send me the dump of NVRAM?
            I may be able to decrypt those passwords
            • bmwmick
              • Jul 2019
              • 27
              That service mode will reset all the data back to factory
              And delete the address book
              • sandmanmac
                • 3990
                Incorrect.
                SP5-846-046 ONLY resets Supervisor credentials and address book.
                I run it with every single machine that I re-sell
                • DRichard
                  • May 2008
                  • 482
                  Originally posted by sandmanmac
                  Incorrect.
                  This is correct. After performing this particular mode, you are prompted to power the machine off/on. At next power on you will see the screen prompting you to enter new passwords. you will also find Addressbook Data has been deleted. I know of no other data loss.
                  -- Warren Zevon
                  • sandmanmac
                    • 3990
                    I must admit, that I just cross-referenced this model to Ricoh to find out exactly what the discussion was about.
                    I didn't realize that we were travelling all the way back in time to an Aficio 3228C!
                    In the end, I'm fairly sure this process, and some others, don't apply to a model that old
                    • DRichard
                      • May 2008
                      • 482
                      Thank You! It didn't even cross my mind that we were talking about a model this old! I revise my response...Here. take my two cents worth of advice and put it toward the purchase of some gasoline and a book of matches.
                      -- Warren Zevon
                      • kplow1986
                        • Nov 2013
                        • 41
                        goto special mode SP5-846 -047 maybe 046
                          • 37590
                          Try Factory SP mode. You will have to contact Ricoh support to learn how.
