Mp c4502 wait warming up..
  • MIGUELMARCHENA
    • Feb 2018
    • 191
    Last month, I asked for help for this same machine, because the power supply was damaged ... well, it was changed and it was solved.
    thank you very much again.
    Now, he has returned to disturb the current in the village, and presented sc 672 ..
    Remove the disk and you can start the machine, but
    It stays in wait warming up,
    Firmware update.
    It didn't work
    I removed the memory to have if the problem remained there, but neither.
    I reconnected all the connectors, nothing.
    So I copied the nvram and proceeded to do 5801 all,
    ..on startup, it shows that the imaging units are not installed but no longer displays "wait, warming up"
    Any suggestion will be very welcome.
    Greetings
    Enviado desde mi H3321 mediante Tapatalk
  • davel
    • Oct 2011
    • 1099
    Re: Mp c4502 wait warming up..
    You have a brick.
    • Notrons
      • Apr 2016
      • 71
      Originally posted by davel
      You have a brick.
      Or a parts machine.
        Firmware update.
        It didn't work
        Greetings
        after the 5801.. did you input the values from the birth cert?
        • MIGUELMARCHENA
          • Feb 2018
          • 191
          Hi good day
          Thank you very much for answering .
          Yes, I have entered the values.
          But on the normal screen, it appears that the imaging units are not installed correctly.
          But they are, and they work fine. They are new
          When reloading the nvram
          The units installed correctly appear, but the message that you expect to warm up remains
          Thank you very much for your help
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Hi good day
            OK the image not installed correctly is usually down to cheap toner installed or damaged toner pwb
            Copying nvram then reloading doesn't really do the job as just putting same values back on machine you needed to do a full smc report then adding default values on sheet with are different to the current values installed as Phil b said its the birth certificate.
            Regards Mark
            • MIGUELMARCHENA
              • Feb 2018
              • 191
              thanks for answering .
              Yes, I know, and they were installed,
              Cheers
                Hi good day
                warm up means there is a suspected problem with the fuser.
                I'm done here.. I don't think he is doing things properly.. just causing himself and us an undue amount of typing suggestions. Looking at his profile, I feel he wasn't trained on anything. BYE!
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Stay safe Phil take care.
                  Regards Mark
                  • mikadonovan
                    • May 2008
                    • 2931
                    Firmware update.
                    It didn't work
                    Greetings
                    Maybe the BRB PCB..
                    https://www.copytechnet.com/forums/r...tml?highlight=
                    NEVER ASSUME ANYTHING
                    • MIGUELMARCHENA
                      • Feb 2018
                      • 191
                      If the machine has a heating problem, does it not have an error code? sc 541,542,552, etc?Thanks for your time
                        did you even go into SM and check the error list? me thinks not.
                        • MIGUELMARCHENA
                          • Feb 2018
                          • 191
                          my esteemed
                          My intention is not to waste time, because I know that in this job, time is what is lacking.
                          I appreciate your suggestions.
                          the errors that the machine has given, visible in 7403, are 672, 672, 670 ... etc
                          At the beginning of the comment I stated that the initial error was 672, and later, everything I have done:
                          disconnect disk, update firmware, check units, connectors, erase memory and reload data, all, also certificates etc etc
                          there it shows that the units are not properly installed.
                          I reloaded nv ram etc to solve the problem of: wait warming up.
                          3 or 4 hours can be left there and there is no fuser error: 540,541, 542, 552, etc.
                          .There is a point that a man mentions ,,, the toner if they have had problems because they install them without removing the seals, damaging the strip.
                          thank you very much for your attention
                          • davel
                            • Oct 2011
                            • 1099
                            • davel
                              • Oct 2011
                              • 1099
                              my esteemed
                              What seals? Has a screw cap on the end to remove.
