Ricoh mp5503 yellow disappear on printed job
  • Pixtech Frameworks
    • May 2020
    • 238
    [Misc] Ricoh mp5503 yellow disappear on printed job
    Hi All,
    A customer ricoh mpc5503 yellow appears when colour pattern is printed, but printed or photocopy jobs, yellow disappears completely.
    For example a job that has Red in it only Magenta appears. I have tried all I could know changing developer, opc drum, OEM toner, it seems not to work.
    Does anyone knows what the issue is??
    Re: Ricoh mp5503 yellow disappear on printed job
    Originally posted by Pixtech Frameworks
    Hi All,
    since it's on COPY only.. have you cleaned the optics?
    then run color cali on the scanner
      • May 2020
      • 238
      It disappears but on copy and print.
        ok DID YOU CLEAN THE OPTICS AND CALIBRATE THE SCANNER?
          • May 2020
          • 238
          Done that already.
          I'll upload print and copy soon.
            Done that already.
            if print is not showing what good would that do? are print pages blank?
            did you run scanner calibration? I don't see how you could IF prints aren't good
              • 37442
              By "did you run scanner calibration?" Phil means User Tools - Maintenance - Auto Color Calibration. In order for the Copy portion to run properly the optics (platen glass, lamp reflector, lens face and all mirrors) must be clean. any dust or toner haze will cause a bad read of the pattern. Run the Copy portion first. That will adjust the scanner circuitry. Then run all Print portion.
              With all models this should be done anytime you have light copy or print. With the Cxx03 models Ricoh put out an internal information letter recommending that it also be done every time firmware is updated.
                • May 2020
                • 238
                Calibration has been done using maintenance method. Colors are complete, but still disappear when copy or print.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  try the bias roller in the ITB image transferbelt unit
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    for yellow.... of course
                    • solorajder
                      • Jul 2010
                      • 106
                      I agree with Mark Bob broken wire for yellow bias roller....already had on a couple of old devices.
                      Sent from my G8441 using Tapatalk
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Hi All,
                        So you printed test pattern in service mode all came out OK then a print job should come out OK it's strange to get good test pattern and bad copy & prints. Please upload samples
                        Regards Mark
                          • 37442
                          That would also cause the yellow on the color test pattern to be missing as well. It is not.
                            • May 2020
                            • 238
                            I've done auto calibration, copy and printing. But when scanning it fails and tell me to start process again. Attached are original and photocopy for more clarification.
                              • May 2020
                              • 238
                              This amazes me that all colours came out ok on colour pattern in service mode.
                              Attached is the colour pattern.
