MPC4503 Print out dirty dot dot at center
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    #16
    Re: MPC4503 Print out dirty dot dot at center
    Originally posted by skinnyb
    I interchange them all the time. P/N is different but they fit and work fine. I use the 04 series drum in the 03 too. They are cheaper. Dev units are unique though.
    Sent from my LM-V405 using Tapatalk
    The black pcu will not fit a colour. and yes 04 pcu's fit in 03 black 04 in black 03 and color in colour
    Regards Mark
    • skinnyb
      • Jul 2008
      • 291
      #17
      I don't have any issues with it. Have done many times. I don't do it unless I'm in a pinch but sometimes you do what you have to do.
      • mikadonovan
        • May 2008
        • 2931
        #18
        After looking at it under magnification, it's most likely caused by one of these things. K drum, failing fusing sleeve, or a buildup on a really effed up pressure roller. I know you said all have been replaced, but that's still what I see. Problem appears to repeat every 3 inches or so. All of these things are really easy to check with your eyes, no swapping necessary.
        NEVER ASSUME ANYTHING
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          #19
          Seen it more and more new drum kit fitted or rebuild non oem pcu
          Buy cheap pay twice
          Regards Mark
          • tsbservice
            Field tech
            • 8019
            #20
            Originally posted by fshead
            stop the printout b4 it goes thru fuser and inspect......
            This. Plus You're looking for something with diameter about 32mm. Print on A3 you should see the repeative patern(dots) 3-4 times. From your sample I guess the distance is about 100mm.
              • 37508
              #21
              Buy cheap pay twice
              Remember the old Fram oil filter commercials?
              Fram Oil Filter Commercial- 1972 - YouTube
              • andrewdecruz
                • Jul 2009
                • 74
                #22
                Looks very straightforward....fuser sleeve or drum.
