Ricoh mpc4504 cleaning mirrors of the scanner
  • Mark Bbb
    • Jun 2012
    • 1662
    Hoi,
    I know how to loosen the scanner block (which hold the mirrors) and flip it over...
    But to clean the mirrors, is it necessary to remove this scanner block totally?
    Or can i clean it in this "flip over" position?
    The service manual is not clear about this issue.
    I like to know "how to..." before i go to customer.
    Thanks for your help!
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Ricoh mpc4504 cleaning mirrors of the scanner
    Originally posted by Mark Bbb
    Hoi,
    Scanner as in optics you don't want to remove cleaning isn't a problem
    Regards Mark
    • Mark Bbb
      • Jun 2012
      • 1662
      There is a small gab at the top of this scanner unit.
      Do i need to clean the mirrors through that small gab?
      Or do i remove the upper cover (seems to contain the expo lamp)?
      Thank for your help.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Just use clean dry soft cloth clean in gap make sure you clean the other 3 mirrors then clean laser slit glass then do acc
        Regards Mark
        • Mark Bbb
          • Jun 2012
          • 1662
          "just..." ?
          For no offend sir, but I don't see how i can do this properly.
          Of course i can clean it with a dry cloth through the small entrance of the gab, but is that the only way?
          You know that after a certain time a bleu greasy layer smear appear on the surface of a mirror.
          And we need to remove that smear through this small gab with a dry cloth, without damaging something?
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            "just..." ?
            Try this
            Regards Mark
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Sorry forgot the 04 series changed scanner assy its one complete assy now
              Regards Mark
              • Gab
                • Aug 2015
                • 677
                Don't remove the scaner ass , just remove only a plate and then clean . If it is too dirty apply cleaner we use for windows and then with dry cloth or soft paper. Try not to leave resedues of cloth or paper.
                  "just..." ?
                  you have ozone build up.(blue greasy film) Clean the mirrors with window cleaner then apply Rain-X AntiFog to the mirrors .. doesn't affect copy quality but lessens the chance of ozone buildup.
                  can you pull the platen glass? if so, with power off move the mirrors to make it easier to clean. return mirrors to home position before power on.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    Just be careful you don't bend a reflector.
                    I've had a follow up call after a tech "cleaned the optics" and bent a reflector plate.
                      Some guys believe in force over finesse.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Try this
                        Many thanks mga, it seems i have not been looking enough in my s.m.
