i ask about Ricoh C901 Fiery print
  • mazin99
    • Feb 2015
    • 4
    i have ricoh pro C901 fiery the fiery have alot of problem and down alot
    so can i use print from machine without use fiery i dont need 330 on 440 only i print a4 or a3 max any one have seloution for this problem
    • 37490
    Re: i ask about Ricoh C901 Fiery print without
    As long as the GW Controller has not been physically removed, check the Fiery installation instruction and reverse the SP changes. One of them switches between GW and Fiery print control and one switches scan service. Just remember, you have to use standard network port on the C901 not the Gigabit.
      • 37490
      Still shows as unread
