sc101-01 at ricoh mp2501
  • alphablaster
    • Nov 2020
    • 32
    [Error Code] sc101-01 at ricoh mp2501
    hi, i have a ricoh mp2501 with sc101-01 but it appears only when I'm using the feeder. I have cleaned the optics and checked that the lamp works when i use the feeder but nothing, any ideas ??
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: sc101-01 at ricoh mp2501
    It's having trouble seeing the ADF white reference plate, is it missing, dirty or scratched?
    Hit it.
      • 37533
      Just because you see the lamp coming on does not mean that it is functioning properly or positioned properly to scan the white reference and that the timing of the lamp turning is correct. If it were happening during platen glass operation also I would be inclined to say the lamp regulator.
      Mechanical items to check:
      1. Foreign matter blocking the projection path from the slit glass to the lens block.
      2. Something causing the scanner head or mirror assembly to tilt when at the slit glass.
      • alphablaster
        • Nov 2020
        • 32
        Nope ! The white plate is ok. The sc code appears only when I use the ADF, i think that if it was the white plate i couldn't use the exposure glass either.
        • TonerMunkeh
          Professional Moron
          • 3865
          Not the scanner white reference plate, the ADF white reference plate. I think it's called a scanning guide plate or something similar, some picture I copied off Google, the white guide that the original passes under when it passes over the ADF slit glass.
          Hit it.
