Af 2045 error sc 322
  • Gab
    • Aug 2015
    • 671
    It copies ok but when printing this error appears.
  • MIGUELMARCHENA
    • Feb 2018
    • 195
    Re: Af 2045 error sc 322
    For copying, the machine handles one resolution and for printing another,
    The beam is "stronger" in print.
    Clean the mirrors and so on.
    Before the LD was removed and the exit of the beam was cleaned with a small ear cup, be careful, it is very delicate,
    other technicians increased the exit when moving the screw, but I repeat, it is very delicate and you risk that it will no longer serve in a copy .
    Now if you just clean mirrors and keep nagging, the LD is damaged.
    Enviado desde mi H3321 mediante Tapatalk
      • 37490
      The problem could also be LD beam pitch adjustment. Resolution during copying is set at 600 dpi. If printing is being done at a lower resolution the beam pitch will be different and could adversely affect sync detection.
