Ricoh MPC3001
  • ATSBMCO
    Technical
    • Oct 2007
    • 70
    Ricoh MPC3001
    Have one which had damaged network port. Pins were bent everywhere.
    Tried fixing the port. Straightening the pins etc.
    Machine booted up, but as soon as I installed the network cable, instantly the machines screen went off and now apart from the power light the machine is dead.
    Ive checked fuses 1-3 on the control board but nothing is blown.
    What else could it be?
  • Codex
    • May 2008
    • 701
    Re: Ricoh MPC3001
    Blown Bicu or controller board
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
    • Codex
      • May 2008
      • 701
      Re: Ricoh MPC3001
      There are micro fuses on the Bicu and controller, there is a "0" on it.. Check these
      • Polarbear
        • Feb 2012
        • 1070
        Re: Ricoh MPC3001
        That is correct. They are normally in the region of the large white connectors with thicker metal pins, towards the bottom of the board. A quick check is to see if all these have a clear white "0" on them. If it is yellow of brown it is a dead giveaway!
        Then do a continuety test over it with a DMM and you can confirm if it is dead that way!
        Then the fun starts of finding a replacement AND getting that replacement soldered on the board!
        Press the GREEN button!!
        • fshead
          • 2376
          Re: Ricoh MPC3001
          they used those micrfuses on the older mpc2800/3300 series and i just soldered a small piece of wire across them when i had the laser motor
          cause them to blow.
          maybe find an old parts machine..
