ricoh 7000 reset fusing unit correctly message
  • ben
    • May 2025
    ricoh 7000 g080 reset fusing unit correctly message
    Hello guys
    I have a message on a copier ricoh 7000:
    ""reset fusing unit correctly"" message
    Iam only find something on page 6-27 in the service manual, but till now after a couple of hour I do not find the problem
    somebody had some advised
    I try already another fusing unit with now result.
    thanks in advanced ben
  • Vesigoth
    • Mar 2008
    • 133
    Ricoh 7000
    Hi Ben,
    Try getting into service mode (All Reset, 1,0,7, Stop and hold down the stop key) go to Data log find S/C jam reset shut off the main power switch, wait 10 seconds and turn on the copier again. Good luck.
    • E Winter
      1. I think it's not a good idea to spread this information (how to enter sp) in public
      2. that key combination won't work on a CL7000
      I think the display message is not refering to a SC code. Sounds like the fusing unit isn't set up correctly - check the parts wich are involved in the detection of the funing unit.
      Check also the fuser connectors if there's stucked paper inside (I'd bet this is your problem).
      • ben
        Hello Jan,
        I now the service code, the 7000 with have the problem don't had a scanner.
        But that s not the problem, i have also all service manuals.
        But i check already or there is paper somewhere but there is no paper.
        I try already another fuserunit from a running m/c, an the problem is still in these m/c. and the other m/c is running with the fusing unit out the problem m/c.
        I have 15 years experience with another brand of copiers, but lesser experience with ricoh.
        Which parts do you mean with"" check the parts wich are involved in the detection of the funing unit."""?????
        I hope somebody had more idees.
        best regards ben
        • E Winter
          Have you also checked the fuser connector of the machine if there's stucked paper inside? This is sometimes not easy to see at the first look.
          There's also a sensor wich is detecting the fuser paper exit feeler but afaik a broken one may just force a paper jam message.
          • ben
            hallo jan,
            Yes i check your suggestions already, but i have the same problem with 5 the same printers!! All just imported!!!
            Ben
            • TonerMunkeh
              Professional Moron
              • 3865
              All imported? From where to where?
              Just thinking out loud here, but say the imported machine is using a different voltage to the fusing unit you have in it, that would explain the odd errors, especially with all 5 of them doing it. Could be the machine's aren't getting enough power too.
              Hit it.
              • KopyKat
                Nurse Ratched of Repair
                • Nov 2008
                • 366
                Double Posting
                This is exactly what I told Ben over on this thread two days ago. There are two threads on this same issue...here in this forum and here
                Should have the two threads merged.
                sigpic
                Relax! This firmware injection won't hurt...but it will take 45 minutes.
                • imaginemoko
                  unTrusted Tech
                  • Jan 2008
                  • 289
                  it may look like the machine is for 220v then you put a fusing unit working for 110v even same model it will appear a fusing setting error, basically its obvious the difference. secondly connector pins male to it female chassy has also diffrent configuration or pins connection....if maybe this is the case.. well... maybe we could solve the problem sir...
                  fix the customer first then fix the machine... its simple and makes life more easy.
                  • E Winter
                    agree - different marketing and/or voltage areas may have different pin assignments on the connectors.
                    • ben
                      thanks for all advised.
                      The machines with the problem gives after switch on, shortly the message "" Ipsio RX 8200""
                      also: setting 5009 has only 2 settings, normally you can set around 10 languages!
                      On the cover next the m/c number is writen 7000
                      after replace the bcu and controller board from a running 7000 the message was gone. conclusion nothing wrong with fusing unit.
                      I think that the problem is in the firmware.
                      can somebody send the files for the sd card to do a firmware update
                      thanks in advanced.
                      ben
                      • Eric1968
                        • 2458
                        Originally posted by Vesigoth
                        Hi Ben,
                        Giving this information is asking for trouble!
                        Reset Fusing Unit means that the Unit is not making good contact with the machine. Has nothing to do with resetting a fuser error.
