MPC2504ex with SPF
  • GeorgeBest
    • Jul 2009
    • 526
    MPC2504ex with SPF
    Hi,
    Does anybody know if you can place an ADF instead of the SPF which is installed . . .
    In my memory I thought that this is not possible.
    Thanks in advance
    gr George
    • 37490
    Re: MPC2504ex with SPF
    Not possible. If you look at the installation of the SPDF for the Cxx03 models you will notice that the ARDF and the SPDF require different BCU PCB. The IPU for the CIS mounts on the SPDF BCU.
    • FrohnB
      • Jul 2017
      • 1919
      Didn't think this model came with a SPDF???
      ARDF is the standard option for this model.
      So if it has a SPDF on it and it's working, then I would assume you could switch to regular ADF. Would just have to make sure and upload the right firmware for that ADF (ARDF 3090 f/w.).
      Omertà
      • mikadonovan
        • May 2008
        • 2931
        ▪ 100-Sheet ARDF for the MP C2004ex / C2504ex
        ▪ 220-Sheet SPDF for the MP C3004ex / C3504ex / C45004ex / C6004ex
        NEVER ASSUME ANYTHING
        • FrohnB
          • Jul 2017
          • 1919
          You are correct Slim.
          I forgot about that board being different to accommodate the CIS.
          Omertà
