Savin 2535 print too light
  • digihlp
    Any suggestions of what could be causing the print on page to be getting lighter whether scanning or sending doc from pc for printing lighter/darker setting on screen at defaualt (in middle) New oem toner installed
    Print has been getting lighter over time
    Savin 2535 model
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    Ok, a few questions:
    1) Are you saying that the copier is light all of the time or only when scanning? If you do an internal printout, or even the meter, what does the density look like?
    2) In the SMC settings, are your voltages way out-of-spec in their ranges from default settings?
    3) When has a PM been done? This machine is 150k, and won't really go much past this. I think the dv is rated to 300k, but I changed it at 150k with the rest of the PM.
    4) In the toner hopper, there are plastic "fins" that can come loose, and this will affect toner getting into the dv hopper. These machines have small dv units and can get out-of-spec quickly with their TD references.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • digihlp
      re: light print
      all printed material is light even scanning i will follow the procedure you asked for and repost the results
