c3004 sometimes random black dots in center and offset
  • Mark Bbb
    • Jun 2012
    • 1662
    Offset: 3,74" or 9,5 cm interval.
    A pattern (width 0,18" or 0,5 cm) of black dots (at random places) exact in the center of the printout.
    This band is formed in the direction of the paper movement (not transverse).
    total counter: 429K
    Only the ITB cl unit has been replaced.
    I have looked in the S.M. for this 3,75" interval, can't find it.
    Can you help us?
    Thank you.
  • davel
    • Oct 2011
    • 1108
    Re: c3004 sometimes random black dots in center and offset
    Replace the rest of the PM parts.
    • FrohnB
      • Jul 2017
      • 1919
      Service manual says the Drums and Fusing sleeve are the same diameter - 94.2 mm - which is 9.42 cm or about 3.71".
      I would start with those first - K Drum, and Fusing sleeve.
      Omertà
      • Mark Bbb
        • Jun 2012
        • 1662
        Frohn, thank you!
        May i ask you where to find these info in the s.m.?
        • FrohnB
          • Jul 2017
          • 1919
          Originally posted by Mark Bbb
          Frohn, thank you!
          Under 'Troubleshooting' --> 'Image quality problems' --> 'When an abnormal image is created' - a page or two down from their gives a list of all the diameters for rollers and such.
          Omertà
          • Mark Bbb
            • Jun 2012
            • 1662
            Thanks Frohn, found it.
            Today i replaced the F.U. ass'y, and the band of dots in the middel of the printout was solved.
            But not the offset, that would be very likely the pcu BK, which i will replace tomorrow (stock 0).
            In my experience with the old models, i would have thought that the dots would be the pcu and the offset the F.U.
            But no, no, no ... these are modern times.
              • 37628
              I have found over the years that offsetting can very frequently be the pdcu. If the developer is slightly over toned it can place more toner on the drum than the cleaning blade can remove in one pass. One thing that you can try is reducing the toner density in the developer and slightly increasing the transfer current. The attached document has the settings for older models but the specific SP numbers were changed with the Cxx03 models. Service Program (SP) Settings.pdf
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                total counter: 429K
                Can you help us?
                Thank you.
                Samples would be good
                Also if that machine has done 429k you probably find the pcu would of already been replaced was it a oem one
                Regards Mark
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Correct, but .... you know
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Replaced BK pcu this morning.
                    Few ours ago customer called: problem with the band of black dots in the center of the page, is back (not the offset).
                    Developer-box is my next best guess.
                    I which i could upload pictures, but for some reason i don't understand, i can't!
                    I'm afraid i need to contact "make a which foundation" for that.
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      I try (again) to upload a test chart page with the dots.KAC c3004 dots center.pdf
                      • Gary k
                        • Jan 2020
                        • 10
                        tech bulletin DAOC-034 there is a warp in the developer housing. Ricoh has a mylar to fix the issue Part# M0AJ3135
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          These dots in the center will only appear at multi print.
                          Replaced developerbox today.
                          Waiting to see if it is solved...
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Jep, that was the issue. Thank you for sharing.
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              I think it's RTB rd239095 and part number M0AJ3138
                              Regards Mark
