Ricoh MP C6003 Factory Reset
  • palanthony
    • 2
    I just purchased this unit. When i go to make a color copy i get a password screen. How do I get rid of that? Please help since I know there are codes for Ricoh copiers.
    • 37550
    Re: Ricoh MP C6003 Factory Reset
    Since it is asking for a Password on the Copy Function it sounds like a user login. Open User Tools. If there is a LOGIN button at the top right of the touch screen try logging in as as admin with no password. If you can login go to System Settings, Administrator Tools, User Authentication and turn it off.
    • Gift
      • Mar 2011
      • 2459
      Within the user tools screen try and hold the #key and press System Settings, this should wipe most of the customized settings back to default. You might have to log in like slimslob says.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Not passwords you will have to log in as slimslob but if passwords be changed you have to reset in factory service mode.
        Regards Mark
          • 37550
          Another thing that I just thought of, if it is a user name that it is asking for then go into SP mode System SP 5846-051 and backup the address book to an SD card. You should then be able to read the resulting file. You can also backup the address book in WIM but may need the admin password to do so.
          • Brianneoe
            • May 2015
            • 322
            You can also try to log-in as "supervisor" no password. This will allow you to clear out or change the the admin password. 9 times out of 10 when the log-in password is changed they don't change the supervisors password.
              • 37550
              Just remember, the supervisor can only change the admin credentials. Once you have changed or deleted the admin password, you have to login as admin to make any other changes.
