Ricoh C5100s: internal cooling fan is active
  • cxtqd
    • Jan 2011
    • 46
    Ricoh C5100s printing 6 paper error : internal cooling fan is active and stop printing...
    Engineers please guide how to fix it. Thanks
  • Brianneoe
    • May 2015
    • 318
    Re: Ricoh C5100s: internal cooling fan is active
    "Internal cooling fan is active" alarm usually does not cause the machine not to work. A better screen shot is needed.
    • JaysOnTheEDGE
      • 61
      Change all of the filters (+ ozones) there are 6 or 7 of them and clean all the toner / dust out from the vents and go from there. Machine is running hot and the fans are cooling it off probably from restricted airflow.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        +1
        Regards Mark
        • zulufan1
          • Oct 2009
          • 45
          I agree, and don't forget the filters on the Toner Hopper assy. 1 On side and 3 on the bottom, behind cover. I believe there are three under the Right cover of main machine as well.
