Ricoh mp5000 not adding toner
  • Jama
    • Jul 2020
    • 49
    [Misc] Ricoh mp5000 not adding toner
    Ricoh mp5000 not adding toner, all pm parts new including drum and developer, toner motor working ok . but fo sp# 2220 initial level always shows 3.5/4.0,when adjusted , machine loads toner. Any leads to this problem will highly appreciated.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Ricoh mp5000 not adding toner
    Replace developer and clean mag roller it should be silver colour not black and setup.
    But may need new Dev assy
    Regards Mark
      • 37489
      If the mag roller has a black film adhered to it then you may also need to clean out the entire toner recovery to remove all contaminated toner. These models are highly susceptible to developer/toner contamination. Use of anything other than Genuine Ricoh toner and developer is highly discouraged. Here is the Ricoh-USA bulletin on the problem. 007-rfg032790.pdf
      • Jama
        • Jul 2020
        • 49
        Seen, I will see if check on other Dev Assy.
        • Jama
          • Jul 2020
          • 49
          If the mag roller has a black film adhered to it then you may also need to clean out the entire toner recovery to remove all contaminated toner. These models are highly susceptible to developer/toner contamination. Use of anything other than Genuine Ricoh toner and developer is highly discouraged. Here is the Ricoh-USA bulletin on the problem. [ATTACH]47593[/ATTACH]
          Thanks will try this and see outcome, will update on same
          • ShonRipz
            • May 2017
            • 33
            Ricoh instructors recommended i clean the mag roller with folded up paper. i personally would use a scotch brite and lightly scuff until the black was all gone. just be aware that everytime you do this, it will contaminate a little faster each time.
            • Jama
              • Jul 2020
              • 49
              NOTED
                • 37489
                Just be aware, scotch brite pad can damage the mag roller.
                • rthonpm
                  • Aug 2007
                  • 2854
                  Don't use folded paper, use a piece of paper wadded up and crumpled into a ball to give you irregular ends and crevices. I've been using this to clean mag rollers for years. It's hard enough to remove any developer deposits, but soft enough to keep the coating on the rollers.
