Savin 920 Firmware Update Procedure
  • mbennett
    • May 2012
    • 5
    Have a Savin 920 that needs firmware updated. I have the firmware, but need the proper procedure to do the update.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Savin 920 Firmware Update Procedure
    Tis the SD card / romdata method. FWU files should be placed in a folder called romdata on the root of a blank, non-HC SD card of a capacity ideally less than 1GB or partitioned down. Stick it in slot 2 on the controller, power the machine up, it will have a nosey at the card then you select the firmware you want to update on the screen. Easy.
    Hit it.
      • 37535
      The complete instructions are in the Service Manual. Follow the service manual exactly.
