MPC4503 image repeating
  • GeorgeBest
    • Jul 2009
    • 520
    Hi,
    light image repeating occurs on some prints, not often . . .
    I know this is an issue with the temp adjustment of the heater.
    Increased the press temperature in every mode to 122. (default 118)
    Mostley the offset and image repeating is gone doing the adjustment and increasing the temp.
    On this MPC4503 however the symptom returns, not often but stil . . .
    remarkable fact, only in color mode, and only the color toners are from Katun, coincidence?
    thinking of replacing the sleeve unit.
    anyone?
    Thanks in advance
    gr George
  • fshead
    • 2360
    Re: MPC4503 image repeating
    [I used KATUN PRE 2000 when getting OEM parts were not easy.
    And on some machines but Katun is mostly cheap chinese crap and they dont test their stuff..
    Katun,LD all are crap toners and will gives issues..
    I would make them eat the dime and pay up for OEM.....
    gr George[/QUOTE]
      KayTon is crap. Buy genuine OEM toners. Ricoh doesn't like crap toner, neither do I.
      • Reed
        • Feb 2011
        • 259
        make sure you use OEM Parts and toner. I had this problem on a Ricoh once. Used NON -OEM rollers/belt. Reinstalled and then started double imaging. Had to order OEM roller/belt and the problem went away. Hard lesson to learn
        • Gift
          • Mar 2011
          • 2458
          Originally posted by GeorgeBest
          Hi,
          anyone?
          Thanks in advance
          gr George
          Yeah I think you found the issue by yourself
          It might work if you set the fuser temp even higher (+10 above default) but it's likely that you're still going to face issues.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Hi,
            anyone?
            Thanks in advance
            gr George
            Katun unfused in mpc4503 series adjust3612-131-132-133-134
            SET ALL TO 600
            Try this when using rubbish compatible toner
            Regards Mark
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              There's also this
              Good luck
              Regards Mark
              • Gab
                • Aug 2015
                • 668
                Perhaps the problen is the blade . Also perhaps need to replace hot roller. After you use qenuin toner.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Blade? Hot roller?
                  Regards Mark
                  • KOSTAS1975
                    • Mar 2025
                    • 1
                    I found out after rebuilding a lot of hot unit sleeves using non oem parts sush as fixing film and oil supply the mcs had low temp due to aged fuser lamp, increasing temp reduce the problems but not reaolve them.swapping the lamp from another healthy unit solve the problem.so after a lot of brainstorm i decidedto rebuit only one time the fusing unit,second time only new original fixing film and press roller with bearings and drive gears as well.
                    In mcs sush as 4503 and 5503 with high counters i only use original fuser sleeve unit,runs up to 500K very well.
