MPC2500 Duplex Gear
  • ricmartinho
    • 142
    MPC2500 Duplex Gear
    Hi there!
    I need some help finding the PN for this Black gear. On the Parts Catalog I can only find the PN for the small black gear and the white one.
    Can anyone help me with the PN or if it's common to another model?
  • Gift
    • Mar 2011
    • 2459
    Re: MPC2500 Duplex Gear
    Not shure but take a look at chapter "bypass feed section 1"
    • mikadonovan
      • May 2008
      • 2931
      I would say it is the gear from the bypass diagram. They both are 30 tooth gears, but the bypass diagram gear has a what looks like a resin clip holding it on instead of an metal e-clip.
      B238 2711 Gear - 30Z
      NEVER ASSUME ANYTHING
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        +1 looks like it because the cut out. Also on mpc3000
        Regards Mark
        • mikadonovan
          • May 2008
          • 2931
          LOL. After looking at his pics, I thought the gear was being replaced because part of it was broken.
          • ricmartinho
            • 142
            I also thought the gear was broken!
            We will have to go there and take a better look.
            Thanks for your replies.
            • ricmartinho
              • 142
              So here is an update.
              The problem is solved! The first time I went there I was in a hurry and didn't give a proper look. Yesterday I tested all the trays and found a paper clip inside the bypass paper path.
              The positive I get from this is that I learned a new thing about an old machine. I had never noticed that oddly shaped gear.
              Thanks for your replies!
