Ricoh MPC4503SP Fax settings(RX tone times)
  • Juanki
    • Feb 2019
    • 7
    [Misc] Ricoh MPC4503SP Fax settings(RX tone times)
    Good afternoon, I have a problem with the fax configuration on a ricoh mpc4503sp, I can't find where to change the ringtones for fax reception by default it comes configured with 3 and I need to change it to 5 tones, thanks in advance.
    Enviado desde mi SM-A315G mediante Tapatalk
    • 37507
    Re: Ricoh MPC4503SP Fax settings(RX tone times)
    It should be in User Tools - Fax. Look for either parameters. It will not be listed as RX tone times. Try instead something have to do with rings or ring delay. It will possibly be a bit switch setting in the parameter table. You might also be able to set it through WIM.
    • Juanki
      • Feb 2019
      • 7
      thanks for your help, i found it in the manual, it was a bit swich!
      • Polo-022
        • Sep 2007
        • 486
        Hi Juanki!
        Do you mean User Manual, or Service Manual?
        It happens to me searching for the same thing these days.
        • Gift
          • Mar 2011
          • 2459
          fax SP2-103-007 should do the trick
          • Polo-022
            • Sep 2007
            • 486
            That's a gift. Thanks a lot!!
