Gestetner MPC 2500
  • Yetno.0103
    • 63
    Gestetner MPC 2500
    Dear all
    As I know life time of colour/black drum MPC 2500 is 80K. Is it possible to replace colour drum to black drum. if it possible how it work. And how to modification it.
    thanks
  • rthonpm
    • Aug 2007
    • 2860
    Unscrew the RJ-11 connector on the back of the drum unit and pry the connector out of the other slot, then pull the wiring harness out of its space (you can remove the foam that keeps it in place) and then swap it with the one from the drum you are looking to replace.
    • E Winter
      or simply use a cutter and a pinboard needle to "modify" the existing connector - it's done within a minute (with a little practice)
      • TonerMunkeh
        Professional Moron
        • 3865
        I know this is a lot to ask, but can someone (if they get time) do a before and after picture of this modification, a lot of people have mentioned it but I've no idea what to do lol
        I just normally swap the harnesses.
        Hit it.
        • Yetno.0103
          • 63
          That's Right, actually i so confused how to start it. I Agree if some one want make picture how to modification it.
          thanks
          • E Winter
            Check the attachment.
            I already had this image on my hdd - it shows the "black to color" mod.
            • TonerMunkeh
              Professional Moron
              • 3865
              It's that simple eh?
              Well bugger me. I'll try that next time I need to do one.
              Hit it.
              • E Winter
                Yes - the oly problem is that little metal pin inside the plastic but all you need is a little practice
                • SGT_Snacks-64
                  • Oct 2007
                  • 157
                  The Metal pin stops you cutting through, but filing it is no problem at all.
                  You do need to be careful that you cut enough off so it fits into the connector ok, if you don't you can bust up the female connector when pushing it back in.
                  Intel Core 2 Quad Q6600 2.4GHz (Oc'ed to 3GHz - Stock Volts)
                  Asus P5E-VM HDMI
                  4GB (2x 2GB) Corsair XMS Xpert II RAM
                  ATi Radeon 4870 512MB GFX Card
                  2x 74GB WD Raptor Sata HDD (RAID 0)
                  500GB Seagate Barracuda Sata II HDD
                  500GB Hitachi Sata II HDD
                  600W500att OCZ PSU
                  -TOTAL HDD SPACE 1148GB-
                  • Jomama46
                    • 2900
                    I gave up on moding the connector. I screwed up 2 if then and they coded out int the field. I think I cut too much off. Now I replace harness.
                    But I remove the blade, foam and front cover to make a neater job of it. Takes all of 5 minutes.
                    sigpic
                    A+; Network +; PDI+
                    • Lagonda
                      • Aug 2008
                      • 1649
                      If you try the "File off the corner method" make sure the PCU slides home smoothly. If you try forcing it you can break the female socket then you are in Deeeep $hit!!!
                      Its about a 4 hour job to strip the gearbox out of the back to repair it.
