RICOH C3002 (SC572-00)
  • Pixtech Frameworks
    • May 2020
    • 238
    Hi Everyone,
    A customer reported to me that the machines throws up error sc572-00. Does anyone have an idea the solution or have an encounter.
    Thanks for the contribution.
    • 37550
    Re: RICOH C3002 (SC572-00)
    Fusing unit pressure roller does not reach warm up error.
    Thermistor
    Thermostat
    Thermopile
    Fusing lamp
      • May 2020
      • 238
      Thanks.
      I'll check the above following to know the cause or probably change the fuser unit.
      Because, fusing sleeve had been changed twice as told by the customer.
        • 37550
        Originally posted by Pixtech Frameworks
        Thanks.
        Whoever replaced the fusing sleeve may have done so because of the same error when what really needed to be replaced was a thermistor.
        • Gift
          • Mar 2011
          • 2459
          I think for this series there is not a big price gap between a fuser unit or a sleeve plus labour time...
          And yes, since the SC does point out the pressure roller temperature it's probably a faulty pressure roller thermistor.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Hi Everyone,
            Its most probably the pressure roller end thermistor quite common also don't just replace sleeve on its own always replace new oem sleeve assy.
            I always replace sleeve assy, pressure roller, bearings, gears and thermistors then it's job done
            Regards Mark
