MPC 5000 SC866 nomore running Scanner Function
  • ISISTEPHANE
    • Mar 2008
    • 22
    Hi everyone
    Have somenone an idea or know why after upgrade firmwares of a Ricoh
    MPC 5000, scanner fuction disepeard, malfunction with SD authentification (SC 866) and no scanner firmware on the diagnosis report?...
    thx
  • TonerMunkeh
    Professional Moron
    • 3865
    What firmware did you upgrade? Just the scanner?
    Hit it.
    • ISISTEPHANE
      • Mar 2008
      • 22
      engine, systemcopy, lcdc, rpcs,netfile, websystem & webuapl
      • iMind
        Vacuum Cleaning Expert
        • Mar 2008
        • 1116
        should of updated copy system and engine at the same time: you must then update all the rest.
        Engine firmware(2)30-12-2008
        Fax(8)26-1-2009
        FCU(2)26-1-2009
        Font(2)30-9-2008
        Language(3)26-1-2009
        LCDC(4)26-1-2009
        Network DocBox(4)26-1-2009
        Network Support(4)26-1-2009
        Option PCL(2)30-9-2008
        PCL Font(2)30-9-2008
        PictBridge(2)30-9-2008
        Power Saving SubSystem(6)4-2-2009
        Printer(4)30-12-2008
        PS&PDF(2)30-9-2008
        RFAX(4)4-2-2009
        RPCS(2)30-9-2008
        Scanner(4)4-2-2009
        System/Copy(6)26-1-2009
        VM CARD(1)30-9-2008
        Web Support(4)4-2-2009
        Web Uapl
        • ISISTEPHANE
          • Mar 2008
          • 22
          all these firmwares were made at the same time without fax option, and just after this malfunction appeard
          • TonerMunkeh
            Professional Moron
            • 3865
            It is feasible one of the firmware updates had an error in it or you might have a faulty SD card.
            Try rolling back the firmware to the previous version and see if that gets the scanner back. If it does, update the firmware files one by one and test the scanner after each install to see which firmware update makes the scanner disappear (if it does it again).
            Take a backup of the NVram data and print SP mode non default values before you do this. An engine all clear may be necessary.
            Hit it.
            • ISISTEPHANE
              • Mar 2008
              • 22
              that was i was thinking to get back, but the original engine firmware is not available to download....and i hink it could be the key of the pb
              • TonerMunkeh
                Professional Moron
                • 3865
                Doesn't have to be the original one, just one level below the firmware you've just installed.
                Hit it.
                • ISISTEPHANE
                  • Mar 2008
                  • 22
                  only one level for the engine firmware and just after the original...
                  • copytech22
                    • Dec 2008
                    • 33
                    Read these TSB
                    READ 1st rfg033620 deals with sc866
                    and rfg033502 deal with engine fw ug
                    • limo
                      • Jun 2008
                      • 103
                      I have exactly the same problem only in my case the problem happens at installation not due to an upgrade.
                      The machine is a 5000 CSP so no SD card.Printer scanner modules are embedded.
                      According to the related rtb by upgrating the system firmware this problem is solved.
                      I upgrade the firmware but problem was not solved.Iwill upgrade all firmwares to check.
                      Any news for the above problem?
