Sc 285
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Error Code] Sc 285
    Hi friends, my machine is ricoh MP C5502 i test the colour pattern the alignments are not ok then i try to do ITB forced line position adjustment on SP2111 that C, B, A option first i do C option result showing failed i try again anf again then its comes SC 285 error code. Then i go by the manual instruction i chenge from other machine ( ITB unit, all the 4 drum units, laser unit, ID sensor) but still the problem not solved.
    So i need help i want to know how to solve this problem friends please teach me how to solve this problem friends.
    Re: Sc 285
    1) you need to post in the proper forum: https://www.copytechnet.com/forums/r...tetner-lanier/
    2) did you run ACC auto color correction?
    3) changing parts from one machine to another you still have to run the appropriate SM adjustments
    4) you have the manual ... RTFM
    • kanagavel
      Service Engineer
      • Feb 2020
      • 78
      Re: Sc 285
      Hi sir thank you for your reply.
      1) i didn't do the ACC
      2) i don't know what is SM adjustment, can you please teach me.
      3)sorry sir i don't have RTFM, i just refer to the printcopy.info website
      So sir can you please help me to solve this problem
        Re: Sc 285
        R = Read
        T= the
        F = frigging
        M = manual
        if you don't have a real service manual, make a small contribution to CTN, that'll get you a Contributor Badge on your profile then the guys with the manual will probably get you a copy ...
        https://www.copytechnet.com/forums/s...nual-requests/
        • kanagavel
          Service Engineer
          • Feb 2020
          • 78
          Re: Sc 285
          R = Read
          T= the
          F = frigging
          M = manual
          Ok sir thank you for your reply sir.
            • 37507
            Re: Sc 285
            You wasted a lot of time running forced line position and changing various parts but I don't see anything about you cleaning the ID sensor assembly first. Now go and clean the Image Density sensor assembly and any toner hazing around it. If that does not correct the problem, replace the ID sensor assembly with a new one. A new one from Ricoh will come with a sticker that was settings that are specific to that board. If those values are not correct you will continue to have problems.
            • VirginiaKMcGowan
              • Mar 2021
              • 3
              Re: Sc 285
              Hello, I am a college student and I was reading How to Better Manage Your Time As a Student on a website and while reading, by mistake, I clicked on your post. And I am glad I have found your post because my friend also facing the same problem and he still he can't find its solution and I would love to share with him. I hope it will help him out.
                • 37507
                Re: Sc 285
                The problem is most likely a dirty or defective Image Density, ID, sensor assembly. Depending on the machine there are a few other things that can cause it. I would suggest that he obtain a service manual for the specific model he owns as getting at the sensor assembly can vary. You or he can put a request in the Service Manual Requests forum. https://www.copytechnet.com/forums/s...nual-requests/
