Savin 2545 How to modify Scan network location
  • IT Tropolis
    • Jan 2021
    • 5
    [Misc] Savin 2545 How to modify Scan network location
    Hi:
    I inherited a quite old Savin 2545. It has an address book entry for scanning to a network folder (SMB) that stopped working. We can still print to the machine and IP address/networking did not change. I cannot figure out how to modify the address book entry/scan location settings. If I connect to the machine via browser at IP address then select Configuration, it wants me to logon. I've tried all the default credential combinations I've found online but none of them work. At the machine console, I've gone through all settings and cannot find anywhere to set/modify address book/scan locations. When I search online for how to cfg. machine, the screenshots are all different than what I see on this machine, as if the firmware is perhaps old. I've attached a screenshot below of the embedded web server/browser page when connecting to the machine.
    Thanks for any insights! If you're a copy tech. in SoCAL (LA/OC) and you can help, my customer will pay for service.
