8002/6502 clear unit
  • Ludlf
    • Jan 2021
    • 3
    [Jamming] 8002/6502 clear unit
    Today my MPC8002 show need to change BK clear unit.
    When this message showed out I will change it's wax bar but this time it still show the message.
    I try the way to fix it but didn't work:
    1.change wax bar
    2.Exchange BK and C's PCU
    3.Change a new clear unit
    I meet another problem: SP3040 can't run
    P.S. PM counter is 0
    • 35067
    Re: 8002/6502 clear unit
    SP 3040 will not rum if then most likely lubricant end detection flag is not 0. Check SP 3810-021 for K. If it is 2 for Near End or 3 for End the PM counter has not been properly cleared. Follow 3.4 PM PARTS SETTINGS in the service manual exactly.
    • Ludlf
      • Jan 2021
      • 3
      Thanks SP3810-021 is show 3.
      Other question is service manual make me to run SP 3040-01~06 but it show failed.
      Had any way to reset PM counter?
      • TonerMunkeh
        Professional Moron
        • 3873
        3701-xx for the item being replaced is the quickest way.
        Hit it.
          • 35067
          Section 3.4 of the service manual gives the step by step procedures for resetting the PM counters. It is different from previous models. If not done properly the detection flags will not be cleared. If the detection flags are not all at 0, DEMS execute, SP 3040-xx, will fail.
          If your service manual is too old it may not include the following Important message:
          If the counter for the Lubricant Bar is reset in SP 7622-XX, make sure to set the
          flag in SP3701-XXX. Otherwise, the lubricant end detection (SP3810-XXX) will
          not be reset and the banner message indicating near-end will remain on the
          operation panel.
          This was added in February 2014, 5 months after the initial printing.
          • rthonpm
            • Aug 2007
            • 2837
            The most convoluted replacement method Ricoh has ever come up with. This has tripped up so many techs, it's just ridiculous they couldn't fix this through a firmware update.
            Sent from my BlackBerry using Tapatalk
            • Ludlf
              • Jan 2021
              • 3
              operation panel.
              thanks your message I solved the problem.
