ricoh mp c6502 sc 569-2/ 569-4
  • danideglew
    • Feb 2018
    • 5
    [Error Code] ricoh mp c6502 sc 569-2/ 569-4
    hello, I have a ricoh mp c6502 with this code, it gives it at the beginning, the fuser unit I tested it on another c6502 and it works fine, there is no paper in the connectors the pressure motor works, did it happen to someone?
    Re: ricoh mp c6502 sc 569-2/ 569-4
    did you c;ear the error in SC mode?
    reset error code sc562-02 on ricoh mp c4503 - YouTube
    • MIKON
      • Jul 2015
      • 188
      try setting sp1151 01 to 1
        • 37533
        My experience was that it only requires a piece of paper the width of the contact tabs in the machine side of the drawer connector to cause the problem. You need to use a bright flash light and look for a connector position that looks slightly different.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          +1 for this
          • danideglew
            • Feb 2018
            • 5
            yes, but it didn't work
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Hope this helps
              Regards Mark
              • danideglew
                • Feb 2018
                • 5
                yes, the sc disappears, but no fusing.
                • danideglew
                  • Feb 2018
                  • 5
                  Originally posted by mga
                  Hope this helps
                  Yes, I saw the technical bulletin, but it does not apply in this case
                    • 37533
                    That is because it is for the C4503.
                      • 37533
                      And what makes you say that it does not apply?
                      • danideglew
                        • Feb 2018
                        • 5
                        now stay sc 569-4
