Scan to tablet
  • mikadonovan
    • May 2008
    • 2931
    Scan to tablet
    Hi, All. I hope everyone is having a good day. This may be a stupid question, but a new install requires setting up scanning to a Microsoft Surface tablet. Do I do it just like any win 10 PC?
    NEVER ASSUME ANYTHING
  • ridgemill
    • Sep 2017
    • 191
    Re: Scan to tablet
    Should be the same, if the customer hasn't re-installed a custom OS, it should be running normal Windows 10. The menus will look different if it is in tablet mode.
    • K-3
      service technician
      • Feb 2018
      • 51
      Re: Scan to tablet
      if not you could try the ricoh smart connector app
        • 8254
        Re: Scan to tablet
        Good chance the customer might be a MS365 subscriber. It could be a lot easier to scan to their OneDrive for Business account.
        OneDrive monitors "watched folders"on the local PC and automatically uploads any file that arrives in that folder.
        • socoolone
          • Sep 2015
          • 22
          Re: Scan to tablet
          As long as the os is windows 10 pro you should be fine just setup a folder and scan to smb. make sure smb components are installed under windows features
          • rthonpm
            • Aug 2007
            • 2859
            Re: Scan to tablet
            The only features for SMB under Windows Features are for SMB1 which at this point shouldn't be turned on for any reason. Out of the box, Windows 10 will negotiate a connection for SMB2 or SMB3.
