MP3054 making a copy job .
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Don't know if possible, but customer askes this question:
    a set originals needs to be copied on different paper, before he had an Konica where he saved a copy job, he created this job, for example
    a set of 5 originals, original 1 and 2 must come out cass 1, number 3 and 4 comes out cass 2, and the last out of cass 3.
    He stored this copy job temperorarily to make a large number of copies of that set.
    Is this possible to create such a copy job on any Ricoh machine?
    Looked in the manuals but can't find it . . .
    anyone?
    Thanks in advance
    gr George
    • 37489
    Re: MP3054 making a copy job .
    It is called batch mode. It allows selecting different trays and whether one sided or two sided. It should be in the operators manual. If it is something that has to be done frequently it can be saved as a special program. You might even be able to put the special program as a home screen selection.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by GeorgeBest
      Hi,
      anyone?
      Thanks in advance
      gr George
      Yes you can it's called cover and slip sheets it's in the user guide under advanced copier settings
      Hope this helps
      Regards Mark
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        As techs, we tend to refer to service manuals before most anything else.
        Never overlook user materials when it comes to the actual use of the machine. Often that is the only place the info exists, as it is not actual service information.
        FWIW, another frequently ignored resource is the PSG (Product Support Guide) for the specific model. There is a wealth of useful little nuggets there.
        • tsbservice
          Field tech
          • 8016
          Absolutely agree. User manuals are bookmarked on both of my work and home(I know it sucks but don't care) PCs.
            • 37489
            The product support guide is smaller and therefore faqster to open than the parts catalog and usually has all the maintenance paats listed as well PM kit numbers.
            • Mark Bbb
              • Jun 2012
              • 1662
              waarschijnlijk met 'kaft - tussenblad'
              Probably with cover - interleaf
