Perfect binder GB 5010 SC 754-15
  • bojans
    • 1313
    Hello,
    Does anyone have experience with this GB5010?
    It was working, and after jam and force open front door it showed SC754-16.
    I checked sensor and solenoid, everything is ok and working.
    Now it has SC 754-15 and seems that problem is in master control board, but we don't have spare board to check. Anyone had this error before?
    thank you
    • 37491
    Re: Perfect binder GB 5010 SC 754-15
    What production model is the GB 5010 connected to?
    • bojans
      • 1313
      Pro C 7100x
        • 37491
        SC 754-15 Perfect Binder: Front door lock release error
        The front door lock release sensor did not go ON, even though the door was unlocked.
        Front door lock solenoid defective
        Front door lock release sensor defective
        Connector loose, broken, defective
        You apparently damaged something when you forced the door open.
        • JaysOnTheEDGE
          • 61
          Did you come up with a resolution yet? Have a few of these in field, not much goes wring with them but always looking to learn about them whenever I can.
          • bojans
            • 1313
            Unfotunatelly, I didn't. Sold 7100 that it was attached to,so I left it in garage until get new machine.
