Different Counters in SP mode - user mode
  • Mark Bbb
    • Jun 2012
    • 1662
    no pic's to be posted. Sorry
  • SteinarN
    • Apr 2021
    • 114
    Re: Different Counters in SP mode - user mode
    Has the machine printed out a significant number of sheets other than A4 LEF? Specifically A3 format?
    • TonerMunkeh
      Professional Moron
      • 3865
      Is A3 double click switched on?
      Hit it.
      • Mark Bbb
        • Jun 2012
        • 1662
        T.m., thanks, i'l check it out tomorrow
          • 37533
          It appears the machine has fax installed. That is why the B/W total is more than the total of printer B/W and copier B/W. The counter page only gives the billable counts. It does not include system printouts like the fax results pages or even the counter prints. And it does not include anything printed while in service mode. The numbers in SP mode are true counts of everything that exits the unit.
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            Theyw are your pm dev count usage you don't use these for your counter print out they are parts life
            Regards Mark
            • SteinarN
              • Apr 2021
              • 114
              I had a look at the numbers for mine machine, MPC2051. It has no fax installed.
              Numbers in user mode are almost identical to 7803-01. User mode: 131.407 pages, 7803-01: 131.372 pages.
              I guess this difference can be explained by me printing out 22 sheets or 42 pages of SMC reports and other reports. And some before me may have done some printing there too
              However, 7803-02, Page:PCU:BK are at 218.733. And in addition to this, 7906-01, previous Page:PCU:BK are at 91.683. Why can this be? Those two counts are at a combined ca 310.000 pages.
              Or aren't those numbers pages at all, but something else?
              • SteinarN
                • Apr 2021
                • 114
                And to add a little bit more confusing, the Fuser unit is at 132.237 pages...
                  • 37533
                  The black PCU and development are also used in color prints. Their counts will be the same as the total of both B/W and color on the counter page.
                  • SteinarN
                    • Apr 2021
                    • 114
                    The total B/W+colour is about 131.000 pages, both in user mode and in 7803-01. While the black PCU are at ca 219.000 pages, and the previous black PCU are at about 92.000 pages
                    My manual states that A3 is double counted though, but even if the machine had exclusively printed out in A3 format I cant get the numbers to add up. Am I missing something? And Mark Bbb too.
                    Is it possible to somehow reset the user numbers and the 7803-01 number?
                    • SteinarN
                      • Apr 2021
                      • 114
                      I'm going to do some testing to see how the numbers in my machine change with different paper size, double/single etc.
                        • 37533
                        SP 7804-001 resets the count in SP 7803-001. Also if a tech needs to correct a problem by replacing the NVRam and properly backs up and restores the NVRam values, jam, SC, and parts history is restored. Total counters are not.
                        • SteinarN
                          • Apr 2021
                          • 114
                          Thanks for additional info, it is beginning to make sense now, for my machine at least, that there probably have been som replacement done in a previous life where som counters have not/could not be restored.
                          Anyway, for what it's worth, did some testing.
                          7803-01, counts +1 for every page printed, regardless of paper size, double sided counts +2 ofc.
                          7803-02, counts +1 for A4, both SEF and LEF, counts +2 for A3, double sided counts +2/+4 for A4/A3, counts for both B/W and color.
                          7803-03/04/05, same as 7803-02 except don't count on B/W ofc.
                          7803-14, counts same as 7803-02
                          Not much of surprice here I guess.
                          For me, I learned something new at least
                          Edit:
                          I have not tested which counts do not increase when printing reports for example.
                            Edit:
                            on the users list any service reports or when put in service test mode shouldn't show...
                            total prints/copies/fax/test service or otherwise will show.
                              • 37533
                              There is also the mechanical lease counter. Might be located under the lower right inside front panel. Usually has has tape covering the opening in the panel. Disconecting t will cause an error if you try to copy or print.
