Pro 8210 with code SC513-11
  • toddanderson
    • Dec 2005
    • 236
    I have a Pro 8210
    With a code SC513-11, has anyone seen this issue before,
    So any help would be appreciated
    Thank you
    • 37487
    Re: Pro 8210 with code SC513-11
    If you have no formal training on Ricoh Production models you should not be trying to work on them.
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      On a production machine you will better of calling a credited ricoh production engineer you could doing more damage than good.
      Regards Mark
        +1
          exactly
          • toddanderson
            • Dec 2005
            • 236
            Thanks for everyone's help. I replaced the Hp sensor .
            The issue is intermittent we will see if the sensor takes care of the issue
            Originally posted by toddanderson
            I have a Pro 8210
            Thank you
            • JaysOnTheEDGE
              • 61
              check drawer unit connectors on rear machine right side facing from front. have had 4 machines throw this code and every one was a 82xx model ad they all had broken connectors on the either the main frame side or drawer unit side. or both. idiots slamming the drawer unit back in really hard or an obstruction blocking the contacts usually will do it.
              • toddanderson
                • Dec 2005
                • 236
                Thank you we will give that a try
                • SteinarN
                  • Apr 2021
                  • 114
                  For what it's worth...
                  This is for the Pro 8110 though...
