Difference C2051 vs C2551, only board "D1065725"?
  • SteinarN
    • Apr 2021
    • 114
    Hi, new question.
    I know the MP C2051 and MP C2551 is practically identical.
    When scrolling through the parts list I find one controller board that is different between those two variants, namely D1065725.
    Is this the only difference between these models? And, a question to copier tech, is the firmware the same between these two machines?
    I cant really find any description in the service manual about this.
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    Re: Difference C2051 vs C2551, only board "D1065725"?
    Originally posted by SteinarN
    Hi, new question.
    The controllers are different please see picture the d104 is the mpc2051 the d106 is mpc2551 the firmware is the same.
    In the picture the one on the right is for mpc2551
    Regards Mark
    • SteinarN
      • Apr 2021
      • 114
      Thank you
      Yes, I saw this in the service manual.
      Ok, so same firmware.
      Then there need to be some difference on the boards telling these two controllers whether it is a 2051 or a 2551.
      This can be a hardware thingy, like a pin on one of the chips connected to ground or 5V for example to tell the chip/controller whether it should pretend to be a 2051 or a 2551. Or some embedded firmware residing in one of the chips.
      I had to open my machine again to have a look. I can't se any obvious (P)ROM chip on the board.
      Investigating further....
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Thank you
        Just so you know you can't make a PCB work on another machine that it's not meant for its not a case of just swapping a chip
        Regards Mark
        • SteinarN
          • Apr 2021
          • 114
          Let's do it the other way around. Say we have a working 2551. Then we start swapping parts from a 2051 into the 2551, except the controller board ofc. At what point/at which part swapped will the 2551 stop working?
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            With the controller.
            All other parts are the same
            Regards Mark
              how many times have we had a user tell us he swapped boards with another machine, just to find he used a SLOWER board on a faster machine or vice versa?
              Too many times....
              • tsbservice
                Field tech
                • 8002
                Thank you
                Ultimately what's your point?
                • SteinarN
                  • Apr 2021
                  • 114
                  I know I can be a pain in the ass sometimes
                  Let say we swap all the parts from the 2051, except the controller, into the 2551. Then the 2551 would work all fine, after all the adjustments ofc. And it would still work like a 2551, right?
                  So, we now have a huge pile of parts from the 2551 laying around, and a very sorry looking 2051, in fact the only part that the 2051 now consists of is the main controller. We now start to put together the 2051 again, pulling parts from the pile we have laying around after the 2551. After a lot of work we finally get the 2051 rebuilt and start it up, do all the factory adjustments etc. And this machine will work like a 2051, right?
                  What we have really done with all this work is we have swapped the main controller, right?
                  Where is the flaw with this line of reasoning?
                  I don't say with any certainty it will work, I am just trying to make a thought experiment
                    no it would function as a 2051
                    • SteinarN
                      • Apr 2021
                      • 114
                      My point, I am very interested in technical stuff, I like exploring possibilities and limits, I like to optimize, I like to investigate.
                      In the end, if I came over a wreck of a 2551 and pulled the main control board from it, what would I need to do to get that board to work in a 2051...
                      As a side note. Previously I installed a lot of residential heat pumps from Toshiba. They had a serie, labeled XXXX-10, XXXX-13, XXXX-16 etc size. On the outdor units the only difference was, absolutely nothing, still the outdoor units knew if it was a 10, a 13 or a 16 size. The way this was done was that there was three wire links which could be cut. From factory all was uncut, and one had to cut to a spesific pattern to configure the outdoor unit to the correct size.
                      I would hazard a guess it could be as simple as this that Ricoh also have done with the controller board to distinguish wheter it should act as a 2051 ot a 2551, except it is not as obvious as a wire link, it could be a smd resistor with different values for example.
                        "In the end, if I came over a wreck of a 2551 and pulled the main control board from it, what would I need to do to get that board to work in a 2051..."
                        can't be done different chips (surface mounted) different timing ...
                        but go ahead and try the least you can do is brick the dam machine.
                        • sandmanmac
                          • 3981
                          For those of you who've been around here long enough, it seems we have the totally unnecessary second coming of aab1 on our hands.
                          I also just discovered that he was, in fact, from Canada, and I apologize on behalf of all of us for the torture he dished out
                            • 37447
                            From what I have seen the last couple of months I would say more than 1.
                              Hey brother no issue with me. I can't/won't go around apologizing for all the dumbasses in my country. No need to for you to do that.
