Ricoh mpc 4502A Background Line in back side
  • muhammadreza
    Lerner
    • Aug 2012
    • 39
    I have a machine Ricoh mpc 4502. When I make copy it will sow some line in backside on paper . I change transfer roller and ITB and fuser but no luck .
    Re: Ricoh mpc 4502A Background Line in back side
    IF they aren't running duplex jobs check paper path and fuser.
    • muhammadreza
      Lerner
      • Aug 2012
      • 39
      No duplex job only single side copy or print
        • 37550
        That mark appears to be right where one of the thermistors contacts the pressure.
        • tsbservice
          Field tech
          • 8028
          Slim he changed fuser.
          OP what are PM counts?
            he didn't say if it was NEW or a pull from another machine... I agree about the thermistor mark
            for that matter he didn't mention if ANY of the parts were new or used.
            • tsbservice
              Field tech
              • 8028
              Agree yes he didn't. I would presume he put used parts so there's a margin of second fuser having same problem...
              • muhammadreza
                Lerner
                • Aug 2012
                • 39
                [QUOTE=Phil B.;1771168]he didn't say if it was NEW or a pull from another machine... I agree about the thermistor mark
                for that matter he didn't mention if ANY of the parts were new or used.[/QUOTE fuser change with other machine
                • muhammadreza
                  Lerner
                  • Aug 2012
                  • 39
                  i pull fuser from another machine but other machine working fine with this fuser
                  • muhammadreza
                    Lerner
                    • Aug 2012
                    • 39
                    when I make copy I try to stop before fuser and i saw Same problem
                      when I make copy I try to stop before fuser and i saw America problem
                      'America' problem? HUH?
                      • muhammadreza
                        Lerner
                        • Aug 2012
                        • 39
                        sorry it was typing mistake 😞
                        • tsbservice
                          Field tech
                          • 8028
                          Then why replace fuser unit instead go for developing unit(probably black).
                          • muhammadreza
                            Lerner
                            • Aug 2012
                            • 39
                            I already change it but no luck
                              • 37550
                              What about the PTR?
