SC142 Ricoh MPC3003 and 3353
  • lukboruta
    • Nov 2014
    • 21
    Hi everyone,
    Most of you know what SC142 code means, its white balance error... ok but its my fault that sc code occured.
    I had some problems with ARDF and MP3353 machine, so I swapped ARDF for other machine....BUT I didnt attach a ground wire (from ARDF to SIO board), i just forgotten (it hided somewhere behind) and that ground cable did a shortcut on SIO board... from that moment the copier gives SC142 code. So i took a SIO board form different machine (MPC3003 - same type of SIO board) and put it into MP3353. Nothing happen... still same SC142 code.... Worst thing is, when I took back that new SIO (that SIO board form MPC3003) and put in to MPC3003 - that copier gives same code too.... So i assume that MPC3353 has destroyed SIO board and some other board which destroyed new SIO board form MPC3003, but do you have any idea which board can be destroyed too?
    Now i have 2 destroyed copiers, in great condition (like new) and Im affraid to swap any other board.... it may be SBU board or IPU destroyed.... the 4-646 mode gives 0011111100000000 errer readings (six "1" means bad white balance readout from the scanner sensor).
    • 37544
    Re: SC142 Ricoh MPC3003 and 3353
    Originally posted by lukboruta
    Hi everyone,
    Are you talking about a MP 3353 Black and White or a MP C3353 which as far as I know does not exist. What made you think that you could take a DF 3090 from a B/W and put it on a color model. Both may use the same model DF but more than likely the DF firmware is different. Most likely the SIO board is OK. The DF PCB, probably not.
    As for the SC 142, most likely causes are Mirrors or lenses dirty or positioned incorrectly or White plate dirty or installed incorrectly
    • lukboruta
      • Nov 2014
      • 21
      Im talking about MP3353 (b&w), ARDF ist the case, now I run both copiers without DF.
      MP3353 worked good until I swapped ARDF's, the ground wire of ARDF (i forgotten to screw down) did a short circuit on SIO board, touched the board and electronics parts. From that moment SC142 occured. Next I put SIO board from MPC3003 (same catalog / part number). It didnt solve the sc142 problem. And when swapped again the SIO board from MP3353 and put into MPC3003 back... both machines show SC142 (looks like MP3353 destroyed SIO board form MPC3003).
      I know most common SC142 reasons and cleaning mirrors, optics, white balance strip were first things I did so its not the reason of SC142.
      SC 142 occured after short circuit. Now I have 2 great copiers with small counter, with great condition (like new) with SC142 on both...
        did you try and clear the codes in SC mode?
        • lukboruta
          • Nov 2014
          • 21
          Yes i tried (theres no reset sc mode) it resets when U run service mode.
          The ground wire did a short circuit on SIO board so its possible other electronic board is defective and destroyed SIO from MPC3003... dont know what to do, Im affraid to swap any boards because of reason to destroy them.
          4-646 mode gives a readout that means all colors (RGB) of the scanner sensor gives bad readout (durong white balance read).
            Ok did you try to reset in SM?
            I WORK only many different brands and sometimes get the damn terminology mixed up..
            Are you trained on Ricoh because your profile doesn't even state you are a tech nevermind trained on any brand.
            • lukboruta
              • Nov 2014
              • 21
              Reset SM ? What does it mean?
              Im Ricoh tech service, im trained on ricoh.... se sell and service Ricoh mchines only... but that problem is so problematic....
                Im Ricoh tech service, im trained on ricoh.... se sell and service Ricoh machines only... but that problem is so problematic....
                you correct my use of SC...
                I said IN SM
                you are contradicting yourself.
                  • 37544
                  SM usually means Service Manual.
                    so where do you reset service codes?
                    • lukboruta
                      • Nov 2014
                      • 21
                      Ricoh SC resets when you run service mode.... there is olny one service mode that resets fuser SC ....
                      i tried to reset SC! And nothing.... We are experienced in Ricoh so we know how to reset SC.
                      experienced
                        • 37544
                        [QUOTE=lukboruta;1777561The ground wire did a short circuit on SIO board[/QUOTE]
                        So you did not follow the service manual when doing the installation. Did you also fail to attach the bracket for the cable as well?
                        Since the data from the scanner passes through the SIO it is most like the only thing damaged unless what the ground wire shorted was a signal coming from the board on the back of the lens. That board is where the white reference data is processed. That board is not field replaceable. In that case you may need lens holder assembly.
                        • lukboruta
                          • Nov 2014
                          • 21
                          I did follow the service manual when doing the installation but when u are in hurry u make a mistake.... dont judge me, just try to help me.... i dont nned the judge.
                            do you take pictures on you phone of the wires connected before you pull the harnesses?
                            in 30+ years in the industry I have never shorted out a board by leaving a ground wire disconnected. AND I ALWAYS double/triple check my work before powering on any unit.
                            i have worked on Ricoh .. Xerox .. Panasonic ..Sharp.. Oki .. Epson... HP and others.
                            " lukboruta;1777725]I did follow the service manual when doing the installation but when u are in hurry u make a mistake..."
                            haste makes waste
                            you don't want to be judged but you don't follow S.O.P. when doing repairs
                            • lukboruta
                              • Nov 2014
                              • 21
                              haste makes waste
                              iN 20+ YEQRS IN THE INDUSTRY I HAVE NEVER SHORTED OUT A BOARD BY LEAVING A GROUND WIRE DISSCONNETED.... do you think i dont check my work? Mistakes are common, dont judge me... i try my best.... every time...
