MPC307 skewing with ADF
  • GeorgeBest
    • Jul 2009
    • 526
    skewing.jpgHi,
    Got this skewing problem on an MPC307, see picture
    not with scanning, or copying on the glass.
    There is no adjustment other then the hinge? (changed them)
    someone a clue?
    * scanning double sided gives just one skewing scan .
    Thanks in advance
  • dave w
    • Jun 2015
    • 230
    Re: MPC307 skewing with ADF
    So the only time it skewing is when you use the ADF.
    Paper guide moving when paper is pulled in?
    check the feed rollers are clean and even pressure.
    The presure plate the pushes the paper to the slip glass, Is that ok?
    Good luck
    • Mark Bbb
      • Jun 2012
      • 1662
      If the skewing is always at the same angle, then a buckle adjustment won't help.
      But, you can try that.
      There is also a skew adjustment in the SP 6 mode.
      I remember lang ago with a 5535 (or something like that) that had the same problem; one of the ADF holes where enlarged with a drill, so aligning the ADF in the wright angle.
      • COPIERMAN
        • Jun 2009
        • 559
        take the adf apart and clean all the tires you might find a piece of paper or staple down in side. I see that all the time. If don't know how buy service manual. Pettery simple to take a part.
