Ricoh 201spf can't change paper size in tray 2
  • surecopy
    • Mar 2018
    • 42
    I am working on this machine and trying to put a second drawer on it. I tried to change the paper size from 8 1/2 x14 to 8 1/2 x 11. Machine is saying you can not perform this task privileges are required to us this function. . I went into admit and tried to change it again and it went back to the same message. I have a different 201 in my office and I put the second drawer on it and was able to change it with no problem. I have never seen this before. Any idea's?
    Thanks in advance. Neil
  • 8T2
    • Aug 2015
    • 257
    Re: Ricoh 201spf can't change paper size in tray 2
    Have you tried changing it via WIM logged in as admin? Sounds like some sort of device/machine administrator blocking you
    Sent from my WAS-LX1 using Tapatalk
      • 37628
      Make sure you are logged in as the correct administrator. It is possible to create 4, 5 if you count supervisor, administrators.
      • sandmanmac
        • 3990
        Agreed...seems an awful lot of the threads these days are administrator authentication issues.
        Blows my mind that some have made it all the way to 2021 without having running across it before.
        I've had to deal with some form of authentication/ security on nearly every machine I've picked up for resale for the last number of years.
        • tsbservice
          Field tech
          • 8064
          On my KonicaMinolta machines user can be restricted to change things like paper size and paper weight...and for good!
          • surecopy
            • Mar 2018
            • 42
            Ok thanks will try that and let you know.
